i'am study electrical engineering. I Have the evaluation board MCBSTR9 from Keil with STR9-11x processor. The HTTP Demo works fine.
My interesting is the following:
--> HTTP Pages shall be loading from the SD Card.
My Problem:
In some threads other peoples talk about the file "HTTP_uif.c" to solve the problem but i didn't find it anywhere on my Keil installatin disk or Harddrive installation path.
My Question:
1.) Where can i find the File? 2.) Have anybody a project where my interested wishes are included or can help me to import and manage the "MCBSTR9_Http_demo" to work with it.
Please help me.....
Thank your for every people help.
Christian
Did you actually build the build or just download an example .axf, bin, etc.
I ask because the question going through my mind is do you have the Keil Real Time library?
The file you mention would be part of it.
Is is not part of the standard compiler, Keil sell it as an add on.
http://www.keil.com/rl-arm/rl-tcpnet.asp
Cheers Darren
Oh
sorry , i have become this product from my university:
http://www.keil.com/mcbstr9/
I think the Real Time Libary is not included. ***
What can i do for my problem to solve it yet?
I never tried this, but you can treat your SD card as a NAND flash - thus, using the MCI driver (you should have it) directly without the abstraction layer of FlashFS.
"using the MCI driver (you should have it) directly without the abstraction layer of FlashFS."
Wouldn't he also need a TCP/IP stack from somewhere...?
To do what you describe, You need two things:
1. A TCP/IP stack (including HTTP Server);
2. A file system to access files on the SD Card
Neither of these, I think, is free from Keil.
See http://www.keil.com/forum/18482/ for some suggested light-weight, free TCP/IP stacks - and note that a version of NicheLite is also available for ST.
For a free & lightweight FAT filesystem, see elm-chan.org/.../00index_e.html
If you look on ST's site (if you can bear it), they may well have an example that does what you require using such free components.
A bit of googling should find plenty of others...
i have solved many of my problems.
But one problem/ maybe it can be that i think in the wrong way is to cast a pointer into a string.
file : HTTP_CGI.c line 170
var = (U8 *)alloc_mem (40); do_format = __FALSE; do_delete = __FALSE; do { /* Parse all returned parameters. */ dat = http_get_var (dat, var, 40); if (var[0] != 0) { /* Parameter found, returned string is non 0-length. */ if (str_scomp (var, "label=") == __TRUE) { str_copy ((U8 *)label, var+6); /* Convert 'label' to upper case. */ for (p = (U8 *)&label; *p; p++) { *p = toupper (*p); } } else if (str_scomp (var, "format=yes") == __TRUE) { do_format = __TRUE; } else if (str_scomp (var, "delete=yes") == __TRUE) { --> Hear i need a variable with the full data of the variable "var"(pointer alloc mem) as string.
I have no idea how it can do this... Maybe a loop over the pointer!!!!?????
thanks
I'm not sure what you mean by that?
In 'C', a string is just an array of char, with a NUL marking the end.
There is no type in 'C' which "holds the full data" of an array - the array name is, effectively, just a pointer to the 1st element.
This is textbook stuff - nothing specifically to do with Keil
c-faq.com/.../index.html
publications.gbdirect.co.uk/.../
http://www.keil.com/books/
