MCB1700 document wrong
When I looked at the document for MCB1700 and it said the USB host on MCB1700 is Micro-AB (5-lines). But I checked the host and found it is wrong. It is USB-type-A.
But when I try to run the USB host MSD_File example on MCB1700. I get error from HyperTerminal:
" Driver not connected, please connect it ..."
The USB stick I used is 2GB FAT16 regular flash with some files on it.
How to run the example? The document is confusing. What Jumper setings should be?
