Thought I would ask the question to see if any one else has come accross this problem before
STM32F103 @ 72Mhz using 4.21 RTX and FS FLASH using the Keil SDIO driver (4 bit mode) for this device SDIO_stm32F103.c using the latest version of the tool chain using a 8K cache not using the journaling FAT ( even worse timing problems) the SD card is transend 2GB - FAT 16 tried formatting in FAT 32 8 other tasks running. rtx configured to run in priviliged mode stack checking Each task has a user set stack thats set to run at roughly 60% capacity already been onto the Keil agent but not heard anything back but it getting pressing as I have a customer who wants a solution asap.
I have a system that data logs - when the system is powered up it opens a file in preperation to log data and then closes it. It tries to open this file in a subdirctory of root.
It then appends a header containing the systems configuration settings.
Once the system is set up and ready, from then on the data is buffered in ram to be appended in lumps of roughly 512 bytes to the file. Can take up to 15 mins + for the data to be collected.
In theory the system should only try to open a file once a day if powered continually * e.g new log file @ 2400 hrs but in practice the power is being removed by to 40 times a day in a particular installation.
It seems the more files thats exsist the slower the file system gets until its just a serious problem for the entire system. eg I have a watchdog that must be serviced and the FS locks the system for so long the watchdog resets the hardware - to the user it appears the product has crashed while displaying a splash screen on a LCD during power up. (Can be between 60 to 110 files in the sub directory)
The name of the file is a long file name eg LXXXXXXXXXXXXXXXXXXX_MMDDYYY_HHMMSS.txt this occupies 4 entries in the root directory entry table. eg file data plus long name.
what I have tried - Debug code *****************************
Opening a new file writing about 1K of data to file and then closing file. Repeat until it affects the a 100mS Keep alive can message sent out via another task.
What I have found is that after a sub directory has more than 52 files in, there is a interruption in the RTX tasks timings and by disabling the watchdog hardware when there is more that 160 files it can take up to 10secs to open a file. (e.g. Timing between breakpoints) furthest I have got is 260 files befoe all seemed dead eg no longer responding to debug. if the SD card is formatted it behaves best, but if the files are just deleted the performance starts to degrade badly at around 70 files.
What I am most curious about is why the RTX is not context switching any more ( eg 100ms CAN keep alive message and watchdog toggling have stopped - 2 seperate tasks - tick time triggerd.
The SDIO transfers are DMA controlled and the filesystem polls status registers bits in a while loop type structure. (In debugging sometime stopping the application when it appears to be stuck the debugger ends up in the loop)
I understand that to open a file it has to find an root directory entry in enter the new data in so say 100 files is 400 entries at 32 bytes each would be 25 + say 6 sector reads ( done with a 4 bit SDIO perpherial) then a couple of writes to place the new data in and update FAT tables etcs. ( sounds simple but I understand the implications) so why does it appear to take 10s or so ? could it be the polled status register is failing to give the sdio state and there is a timeout built into the SDIO_STM32F103.c driver ? Is the RTX context switching buggering this status bit polling up ?
I think I have a rough idea of where I need to look but just wanted to run by this other to see if I have overlooked the obvious and do not want to end up wasting time chasing an issue that doesnt exsist.
TIA Dan
My guess is that it is caused by both the long file names, and the number of sectors that the code is caching in memory. So when browsing the directory, the code performs a large number of walks through the directory information (and the directory is basically a file storing fixed-size records and allocating n records at a time.
When operating on the files, you probably get a truly huge number of sector reads, to constantly read in the start, beginning and end of the directory into swapping RAM buffers.
What happens if you use the epoc time stamp as file name instead, so you get a file name that fits in a 8.3 file name? That should speed up the operation, but how much?
When handling lots of files, you should consider regularly create new directories.
as a quick test I have tried
opening a diriectory based on month and year then opening just one file a day and appending all data to it.
With one new file per day eg 31 files at most per directory it was able to write the equivelent of 3 years worth with it seems like no degradation of the system.
This seems to behave okay but it does require changes to the data written in the header and pc software to analyse the logged data. Plus at the moment the systems settings take about 1.3K so if the system starts 30 times a day there is a lot of data being repeated in the file.
There is a reason for the long file names (e.g. admin and being man readable) but if it cant do the task required becasue of the problems it will have to change.
forgot to add there is 100Kb of data per day.
Yes, but consider:
/year/mon/mday/<time>.log
The issue shouldn't be the number of files in the file system, but the number of files in a specific directory (or potentially, depending on implementation, the total number of files in current directory and all directories above) and how much file name data each file produces.
A FAT file system has a fixed-size directory entry. So VFAT is a way to add many "deleted" file entries to the same directory, where these "deleted" file entries contains the additional text of long file names. So a directory listing must walk through the data to find and combine multiple directory entries just to recreate one "real" directory entry.
And if you have code that wants to list all files in alphabetical order, and that code is implemented without buffering, but "find smallest name larger than current", then every single new file name listed is retrieved by a full scan of all directory entries.
And if all directory entries are too much for one sector of the file system (or maybe one cluster, depending on what caching level the file system code is using), then the code needs to store multiple sectors (or clusters) in RAM when doing this. If the configuration then supports only one or two sectors (or clusters) in RAM, then you get a huge trashing where the same 5 or 10 sectors are reread a large number of times when scanning the directory. A PC with a stupid implementation (MS-DOS) can still manage large directories just because it has many buffers available. And Win95 and forward are not limited by a few kB for a small command.com and can use more modern sort algorithms to read in lots of files and rearange without any n^2 (or worse) algorithm involved.
So maybe you can increase the number of buffers supported. And if you can avoid long file names, you will reduce amount of data that must be processed for a directory scan. And a deeper hierarchical design will reduce the number of files you may produce at the leaf level.
I haven't worked with the Keil FS implementations, so I can't really help with specifics, but their implementation has to be affected by the same limitations as "all other" FS implementations. And many files in a directory or very long files are features that does result in troubles for RAM-limited implementations.
Ive tried various options on writing files to different directorys, name, lengths etc and every now and then it falls over ( the rtx stops toggling the watchdog and the hardware resets) but on restart does not appear to get hung like it used to trying to open a file (file count is around 1200 files in 44 directories) being pragmatic hte solution I have will do for now
Just been informed there is a update to the tool chain because of the Filesystem etc - the links I had to the source for the FS does not seem to be active with a new update so lets find out whats new !
