On executing code from RAM instead of flash...
Hi guys,
I've got a Cortex-M3 (STM32F103) application that updates code in flash.
From what I understand if the FPEC is busy with, say, flash erasing it won't fetch instructions for the core thereby stalling it.
I would like to avoid these stalls so I'd like the flash updating code to run out of RAM.
I'm using a custom scatter file and I'm not initializing anything.
I'm not using any RTOS or libraries.
Ideally I'd be able to define a section in flash where the code is stored so, on startup, I can just copy it into another section in RAM and execute it.
Many thanks,
  • scatter file layout:
    ; * ACCESS TO THE NOR FLASH IS SLOWER THAN TO LPC2478 INTERNAL FLASH *
    ; * DO NO MAP ANY TIME CRITICAL CODE HERE (COMPRESSOR CONTROL ETC.)  *
    ; * USE RAM REGION "ER_NOR_FLASH_RAM_ZONE" TO MAP MODULES TO RAM FOR *
    ; * FAST EXECUTION        *
    LR_IROM2 0x80000000 0x400000  {    ; load region size_region
      FMMAPP2 0x80000000 0x00400000  {  ; load address = execution address
            SYSTEM_ERROR_CODES.o
            APP_CENTAC_V4_FILE_INFO.o
    ; * These modules are executed in RAM (but stored in the NOR flash)   *
    ; * This code is copied into RAM by overriding the "__main" function  *
    ; * so that the scatter loading process of the application can access *
    ; * the NOR flash. See "main.c"        *
      ER_NOR_FLASH_RAM_ZONE 0xA1100000 0x400000  {
            APP_MACHINE_ID.o
            APP_SOFTWARE_UPDATE.o
            APP_IO_CFG.o
            APP_VAR_INIT.o
            SOFTWARE_EVENT.o
            APP_OPTION_MODULE.o
            APP_FEATURE_LST.o
    note how the RAM execution zone is mapped UNDER the load region of the NOR flash.
