Help with movx @r0,a comman and C51,disable XRAM
Hello i have wrote the above code but i use inline assembly to... is any other better way to get the same result ?
i try to read busy flag from a glcd and switch block
void block(unsigned char cs)
    bit busy = 1;
        if(cs == 1)
                cs1=1;
        else
                cs2=1;
         #pragma asm
                mov auxr,#0x0e  ;disable XRAM from 0x00 to 0xff
                mov r0,#check_status
                busy:
                movx a,@r0                      ;read busy flag
                jb acc.7,busy
                mov auxr,#0x0c  ;enable XRAM
         #pragma endasm
          cs1=0;
          cs2=0;
thanks a lot
