A reply to thread-16477
http://www.keil.com/forum/docs/thread16477.asp
I tried to post something on thread-16477, but somehow failed, and lost my original writing. After that, it seems thread-16477 has been touched, and updated with nothing.
What did you try to post?
==> \LPCUSB\target\examples\main_serial.c
/** Local function to handle incoming bulk data @param [in] bEP @param [in] bEPStatus */ static void BulkOut(U8 bEP, U8 bEPStatus) { int i, iLen; if (fifo_free(&rxfifo) < MAX_PACKET_SIZE) { // may not fit into fifo return; // Here!!! } // get data from USB into intermediate buffer iLen = USBHwEPRead(bEP, abBulkBuf, sizeof(abBulkBuf)); for (i = 0; i < iLen; i++) { // put into FIFO if (!fifo_put(&rxfifo, abBulkBuf[i])) { // overflow... :( ASSERT(FALSE); break; } } }
If there is not enough space in the rxfifo (rxdata), the ISR function BulkOut() returns.
In such a case, the EP_SLOW bit in USBDevIntClr Register had already been set (interrupt cleared) by the major ISR function USBHwISR(). But the bEP is still full with data, so the Host application will not be able to write anything into this bEP (OUT-NAK), then, the ISR function BulkOut() will no longer be triggered.
The data in bEP will never be processed. This is a dead-end.
What I tried to post is something very similar to the above post, "Found a dead-end in main_serial.c".
(Still struggle with my USB I/O Board.)
Found another thing in the LPCUSB Library:
/* USB Controller */ #define USB_BASE_ADDR 0xFFE0C000 /* USBPortSel only available on the LPC2378 */ #define USBPortSel (*(volatile unsigned int *)(USB_BASE_ADDR + 0x110)) /* USB Clock Control Registers */ #define USBClkCtrl (*(volatile unsigned int *)(USB_BASE_ADDR + 0xFF4)) #define USBClkSt (*(volatile unsigned int *)(USB_BASE_ADDR + 0xFF8)) /* USB Device Interrupt Registers */ #define USBIntSt (*(volatile unsigned int *)(USB_BASE_ADDR + 0x1C0)) #define USBDevIntSt (*(volatile unsigned int *)(USB_BASE_ADDR + 0x200))
The Address of USB Device Interrupt Registers (USBIntSt) is incorrect.
But it seems that LPCUSB does not use this Register actually.
wiki.sikken.nl/index.php The above Wiki of LPCUSB has been emptied. Don't know how to contact the maintainers of LPCUSB.
