I am trying to run the .NET Microframework on an AT91SAM3S4C board. And I am stuck at the very few steps. I am trying to execute a function which would perform a low level init of the board and execute a few lines of code to toggle the LED.
My scatter file looks like,
LR_FLASH 0x00400000 ABSOLUTE 0x00030000 { ER_FLASH 0x00400000 FIXED { FirstEntry.obj (+RO, +FIRST) * (SectionForBootstrapOperations) * (+RO-CODE) * (+RO-DATA) } ER_RAM_RO 0x00000000 ABSOLUTE { VectorsTrampolines.obj (+RO, +FIRST) * (SectionForFlashOperations) } ER_RAM_RW +0 ABSOLUTE { * (+RW-DATA, +ZI) } ER_HEAP_BEGIN 0x20009000 ABSOLUTE UNINIT { * (SectionForHeapBegin) } ER_HEAP_END 0x2000AFF8 ABSOLUTE UNINIT { * (SectionForHeapEnd) } ER_STACK_BOTTOM 0x2000B000 ABSOLUTE UNINIT { * (SectionForStackBottom) } ER_STACK_TOP 0x2000BFF8 ABSOLUTE UNINIT { * (SectionForStackTop) } } LR_CONFIG 0x00430000 ABSOLUTE 0x00010000 { ER_CONFIG 0x00430000 FIXED 0x00010000 { * (SectionForConfig) } }
As my flash base address is 0x00400000 and I am trying to load a ASM file which will call the Boot fucntion from tht location. But for some reason I am not able to get this to run.
Anyone kindly let me know if they have any inputs/suggestions. Someone who has done a port of .NET Microframework.
Have you tried asking on the .NET Microframework forum?
Yes. I have posted there too. I was just wondering if there were any errors in the scatter file.
Hello Kartik Natarajan,
I am not very experienced in writing scatter files but did you try to place your vectors at the beginning of the Flash?. I think the controller remaps the start of Flash to address 0x000000. At this address it fetches the Stack Pointer and also the Reset Vector.
... ER_FLASH 0x00400000 FIXED { VectorsTrampolines.obj (+RO, +FIRST) * (SectionForFlashOperations) FirstEntry.obj * (SectionForBootstrapOperations) * (+RO-CODE) * (+RO-DATA) } ; ER_RAM_RO 0x00000000 ABSOLUTE ; { ; VectorsTrampolines.obj (+RO, +FIRST) ; * (SectionForFlashOperations) ; } ...
I am not shure if this is the correct syntax.
Best Regards, Martin Guenther
