Hi there
I am using the Keil MCB1700 board with an LPC1768 processor. I am currently writing data to a USB memory stick at regular intervals using the Keil file libraries, but I am having problems as the speed at which I can write is very limited. I thought that it may be possible to write quicker if DMA were activated, but I can't work out how I activate DMA in the Keil libraries. Does anyone know how I could do this?
Thanks in advance, Richard
Sorry, I don't understand..
You probably need to either ask Keil if they implemented it (not ,AFAIK), or do it yourself, which requires you to obtain the sources after you sign a Non-Disclosure Agreement.
