It seems that we have to use the second para "info" in os_tmr_create (xx, info)to distinct which usr timer callback funtion is called.
#define Timer1CallBackFn1 1 #define Timer2CallBackFn2 2 #define TimerInterval1 10 #define TimerInterval2 15 tmr1 = os_tmr_create (TimerInterval1, Timer1CallBackFn1 ); if (tmr1 == NULL) { printf ("Failed to create user timer1.\n"); } tmr2 = os_tmr_create (TimerInterval2, Timer2CallBackFn2 ); if (tmr2 == NULL) { printf ("Failed to create user timer2.\n"); }
Then, we have to modify rtx_confg.c as following:
void os_tmr_call (U16 info) { /* This function is called when the user timer has expired. Parameter */ /* 'info' holds the value, defined when the timer was created. */ /* HERE: include optional user code to be executed on timeout. */ switch(info) { case Timer1CallBackFn1 : //add code here printf("Timer1 expired!\n"); break; case Timer1CallBackFn1 : //add code here printf("Timer2 expired!\n"); break; default: break; } }
So,We can create different Usr timer and its callback funtions, is it ok?
In fact, it is best to do this:
os_tmr_create (TimerInterval, TimerCallBackFn );
Where TimerCallBackFn is a usr function address.
