Dear All,
(LPC 2378)I have Physical connections done on board for USB d2 connector..but in my pin connect block the Pin P0.13 AND P0.14 AND OTHER pins related USB d2 are not present even i am making these pins enable using pinsel function.
USBPortSel = 0x03; USB_CONNECT2 & USB_UP_LED2 PINSEL0 = 0x24000000 USB_D+2 PINSEL1 = 0x40000000 vBUS PINSEL3 = 0x20000000
Please suggest how to make the pins view in PIn connect block and if any other setting is needed to make the USB d2 enable..
Thamks and Regards Hrishikesh.
You have expressions on the left-hand side of your assignment - a copy/paste error?
