How to re-parse the configuration wizard from header files
I like the configuration wizard for setting up processor parameters in header files, and have started using it for my own purposes (setting which product to build for, for example). However if Microvision encounters an error in the configuration script, it shows a messagebox detailing the error and then disables showing the configuration wizard for that header file.
Is there a way of making Microvision try to generate the configuration wizard page from the header file again, without restarting Microvision? Then it would be much easier to correct errors in the configuration script.
Thanks,
John Dominey
