I have a problem with uart interface , I tried to start program " hello wold " but on the serial dont display it please I need help . I will post the code : SERIAL.C : #include <LPC17xx.H>
#define CR 0x0D int sendchar (int ch) {
if (ch == '\n') { while (!(LPC_UART1->LSR & 0x20)); LPC_UART1->THR = CR; /* output CR */ } while (!(LPC_UART1->LSR & 0x20)); return (LPC_UART1->THR = ch); }
int getkey (void) { /* Read character from Serial Port */
while (!(LPC_UART1->LSR & 0x01));
return (LPC_UART1->RBR); }
:::::::::::::::::::::::::::::::::: RETARGET.C
#include <stdio.h> #include <rt_misc.h>
#pragma import(__use_no_semihosting_swi)
extern int sendchar(int ch); /* in serial.c */
struct __FILE { int handle; /* Add whatever you need here */ }; FILE __stdout;
int fputc(int ch, FILE *f) { return (sendchar(ch)); }
int ferror(FILE *f) { /* Your implementation of ferror */ return EOF; }
void _ttywrch(int ch) { sendchar(ch); }
void _sys_exit(int return_code) { label: goto label; /* endless loop */ } ::::::::::::::::::::::::::::::::::::::::::::
HELLO.C #include <stdio.h> /* prototype declarations for I/O functions */ #include <LPC17xx.H> /* LPC21xx definitions */
/****************/ /* main program */ /****************/ int main (void) { /* execution starts here */ uint32_t Fdiv; /* initialize the serial interface */ LPC_PINCON->PINSEL0 &= ~0x000000F0; LPC_PINCON->PINSEL0 |= 0x00000050; /* Enable RxD1 and TxD1 */ LPC_UART1->LCR = 0x83; /* 8 bits, no Parity, 1 Stop bit */ LPC_UART1->DLL = Fdiv % 256; /* 9600 Baud Rate @ 15MHz VPB Clock */ LPC_UART1->LCR = 0x03; /* DLAB = 0 */
printf ("Hello World\n");
while (1) { ; /* ... */ }}
