Hi everyone...
I'm a beginner and i'm trying to generate an Esclator signal from STM32f10e-eval's DAC, witch is configured, i suppose :), to be triggered by TIM3 TRGO trigger...but in debug mode nothing comes from the Logic Analyzer...what's wrong?
here is the main code:
/* Includes ------------------------------------------------------------------*/ #include "stm32f10x.h" /** @addtogroup STM32F10x_StdPeriph_Examples * @{ */ /** @addtogroup DAC_OneChannelDMA_Escalator * @{ */ /* Private typedef -----------------------------------------------------------*/ /* Private define ------------------------------------------------------------*/ #define DAC_DHR8R1_Address 0x40007410 /* Init Structure definition */ DAC_InitTypeDef DAC_InitStructure; DMA_InitTypeDef DMA_InitStructure; TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_ICInitTypeDef TIM_ICInitStructure; TIM_OCInitTypeDef TIM_OCInitStructure; uint16_t PrescalerValue = 0; /* Private macro -------------------------------------------------------------*/ /* Private variables ---------------------------------------------------------*/ const uint8_t Escalator8bit[6] = {0x0, 0x33, 0x66, 0x99, 0xCC, 0xFF}; /* Private function prototypes -----------------------------------------------*/ void RCC_Configuration(void); void GPIO_Configuration(void); void Delay(__IO uint32_t nCount); /* Private functions ---------------------------------------------------------*/ /** * @brief Main program. * @param None * @retval None */ int main(void) { /*!< At this stage the microcontroller clock setting is already configured, this is done through SystemInit() function which is called from startup file (startup_stm32f10x_xx.s) before to branch to application main. To reconfigure the default setting of SystemInit() function, refer to system_stm32f10x.c file */ /* System Clocks Configuration */ RCC_Configuration(); /* Once the DAC channel is enabled, the corresponding GPIO pin is automatically connected to the DAC converter. In order to avoid parasitic consumption, the GPIO pin should be configured in analog */ GPIO_Configuration(); /* Compute the prescaler value */ PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1; /* Time base configuration */ TIM_TimeBaseStructure.TIM_Period = 65535; TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue; TIM_TimeBaseStructure.TIM_ClockDivision = 0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); /* TIM3 ToggleMode configuration: Channel1 */ TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Toggle; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = 16383; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; TIM_OC1Init(TIM3, &TIM_OCInitStructure); /* TIM3 TRGO selection */ TIM_SelectOutputTrigger(TIM3, TIM_TRGOSource_Update); /* DAC channel1 Configuration */ DAC_InitStructure.DAC_Trigger = DAC_Trigger_T3_TRGO; DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None; DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable; DAC_Init(DAC_Channel_1, &DAC_InitStructure); #if !defined STM32F10X_LD_VL && !defined STM32F10X_MD_VL /* DMA2 channel3 configuration */ DMA_DeInit(DMA2_Channel3); #else /* DMA1 channel3 configuration */ DMA_DeInit(DMA1_Channel3); #endif DMA_InitStructure.DMA_PeripheralBaseAddr = DAC_DHR8R1_Address; DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&Escalator8bit; DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST; DMA_InitStructure.DMA_BufferSize = 6; DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte; DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; DMA_InitStructure.DMA_Priority = DMA_Priority_High; DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; #if !defined STM32F10X_LD_VL && !defined STM32F10X_MD_VL DMA_Init(DMA2_Channel3, &DMA_InitStructure); /* Enable DMA2 Channel3 */ DMA_Cmd(DMA2_Channel3, ENABLE); #else DMA_Init(DMA1_Channel3, &DMA_InitStructure); /* Enable DMA1 Channel3 */ DMA_Cmd(DMA1_Channel3, ENABLE); #endif /* Enable DAC Channel1: Once the DAC channel1 is enabled, PA.04 is automatically connected to the DAC converter. */ DAC_Cmd(DAC_Channel_1, ENABLE); /* Enable DMA for DAC Channel1 */ DAC_DMACmd(DAC_Channel_1, ENABLE); /* TIM3 enable counter */ TIM_Cmd(TIM3, ENABLE); while (1) { ; } } /** * @brief Configures the different system clocks. * @param None * @retval None */ void RCC_Configuration(void) { /* Enable peripheral clocks ------------------------------------------------*/ #if !defined STM32F10X_LD_VL && !defined STM32F10X_MD_VL /* DMA2 clock enable */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2, ENABLE); #else /* DMA1 clock enable */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); #endif /* GPIOA Periph clock enable */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); /* DAC Periph clock enable */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE); /* TIM6 Periph clock enable */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); } /** * @brief Configures the different GPIO ports. * @param None * @retval None */ void GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; /* Once the DAC channel is enabled, the corresponding GPIO pin is automatically connected to the DAC converter. In order to avoid parasitic consumption, the GPIO pin should be configured in analog */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; GPIO_Init(GPIOA, &GPIO_InitStructure); } /** * @brief Inserts a delay time. * @param nCount: specifies the delay time length. * @retval None */ void Delay(__IO uint32_t nCount) { for(; nCount != 0; nCount--); } #ifdef USE_FULL_ASSERT /** * @brief Reports the name of the source file and the source line number * where the assert_param error has occurred. * @param file: pointer to the source file name * @param line: assert_param error line source number * @retval None */ void assert_failed(uint8_t* file, uint32_t line) { /* User can add his own implementation to report the file name and line number, ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */ /* Infinite loop */ while (1) { } } #endif
