I'm using RTX + RL-TCPnet on an LPC1788 dev board.
I have the web server enabled and this is working great. In a separate task I have implemented a UDP protocol.
Nothing happens until the following sequence occurs:
All running fine. UDP message received and validated in dedicated task. UDP reply sent. System Hard_faults with an INVPC flag set.
If I receive a message that does not get a reply nothing happens and I can keep receiving.
Is there any reason I would not be able to send and receive UDP packets from a task other than the main_TcpNet task?
Thanks.
M
Make sure to heed this warning:
"Functions are not reentrant. This means they must not be interrupted and called again from another task. All TCPnet-related functionality should be collected in a single networking task"
www.keil.com/.../rlarm_tn_using_withkernel.htm
Thank you. I missed that, and this was exactly the issue.
Regards,
M, Can you post any further info/example on how you got the UDP to work with the RTX. I am having troubles. The micro goes freezes into the default interrupt handler as soon as any UDP messages come across.
thanks, R
In my 'network' task I have additional tick handlers:
while(1) { main_TcpNet(); other_custom_tick(); }
Than in 'other_custom_tick()' I do my non-blocking UDP send receive:
uint16_t udp_callback(uint8_t socket, uint8_t *remip, uint16_t port, uint8_t *buf, uint16_t len) { /* This function is called when UDP data has been received. */ if(socket == my_socket()) { if(port == my_get_port()) { if(len <= MAX_MPDU) { //tsk_lock(); memcpy(rx_buff, buf, len); memcpy(rx_ip_address, remip, 4); cc_len = datalink_receive(&src, &rx_buff[0], MAX_MCC, 1000); //!\todo define proper timeout somewhere //tsk_unlock(); } } } return (0); } void other_custom_tick(void) { /* process */ if(cc_len) { cc_handler(&src, cc_start, cc_len); cc_len = 0; } }
