I recently download Keil v9.03 to use AT89LP6440 but this chip not available in Device Database so how to ADD with Full feature. Please help me
I recently download Keil v9.03 to use AT89LP6440 but this chip not available in Device Database so how to ADD with Full feature 1) download the datasheet 2) find a similar or use the basic 8051 definition, save it with a new name 3) verify/add SFRs (and bit names) as the datasheet tell you 4) save this file 5) it typically takes 1/2 hour or less to do this
Please read the manual: http://www.keil.com/support/man/docs/uv4/uv4_ca_cpu_ndatabase.htm http://www.keil.com/support/man/docs/uv4/uv4_c_dd_parameters.htm
