RTX with External SDRAM LPC1788 - causes bus fault
I'm using the Embedded Artists LPC1788 development kit and I'm trying to get a very simple RTX application running using the external SDRAM.
Here is what I have so far:
1) A simple RTX application that runs (blinks an LED) with no problem when I use the internal RAM. This same application crashes with a bus fault in "os_sys_init" when I us the external SDRAM.
2) I configure and initialize the external SDRAM before the call to __main (this is working as I can run the same blinking LED using the SDRAM with no RTX.
3) Even if I let me STACK and HEAP remain in the internal RAM but have variables etc.. in the SDRAM I get the bus fault.
4) The bus fault is an IMPRECISERR: Imprecise data bus error
The call stack looks like this when the fault occurs:
HardFault_Handler -> rt_put_rdy_first() -> rt_dispatch() -> rt_task_create() -> SVC_Hanlder...
Does anyone have any suggestions? I see no reason why this should cause a fault.
Thanks.
MAC
  • I guess the very first question would be - are you sure the settings of your external RAM are correct? Pins, timing, something? Does it work without RTX being involved? did you run a thorough RAM test (checking all data/address lines and content? And then: Are you sure they are not overwritten during execution?
  • Does the evaluation board need some extra logic to access the RAM? Maybe you need to set a jumper somewhere...?
  • Hello,
    Thanks for your reply.
    Yes this initialization of the SDRAM works fine when RTX is not involved.
    I don't do an exhaustive test of the SDRAM because I've already tested it quite a bit without RTX.
    but just to satisfy myself my main does a little test as follows and always passes:
    int main (void)
        volatile uint32_t *wr_ptr;
        uint32_t data;
        uint32_t i;
        PINSEL_ConfigPin(LED_PORT, RED_LED_PIN, 0);
        PINSEL_ConfigPin(LED_PORT, GRN_LED_PIN, 0);
        GPIO_SetDir(LED_PORT, RED_LED_PIN_MASK, GPIO_DIRECTION_OUTPUT);
        GPIO_SetDir(LED_PORT, GRN_LED_PIN_MASK, GPIO_DIRECTION_OUTPUT);
        wr_ptr = (uint32_t *)0xA0000000;
        for (i = 0; i < 0x100; i++)
            *wr_ptr++ = 0x12345678;
            //*wr_ptr++ = i;
        /* Verifying */
            data = *wr_ptr;
            //if (data != i)
            if (data != 0x12345678)
                while(1);
            wr_ptr++;
        os_sys_init(init);                        /* Initialize RTX and start init */
        while ( 1 );
    Any other ideas suggestions would be most appreciated.
    Mac
  • Hello,
    Thanks. I implemented the test as shown on that web page. It passes the test but still faults as os_sys_init.
    However, that lead me to try reducing the EMC speed (from 120MHz to 60MHz) and it was ok.
    So yes this is a memory issue it looks like. If the test passes what else can I try to see what is going wrong as I would really like to run at 120 MHz.
    M
  • I should have advised you to do so earlier - interestingly enough, I posted a bootloader from a LPC2478 to a LPC1788 lately, and I have the very same problem! Had to run the EMC clock at 60MHz. I assumed then it was a routing issue, but NXP themselves gave up conflicting statements about the maximum clock speed of the chip...
  • Just an update.
    I got it running at 96MHz and it seems alright.
    I also spoke with someone at NXP and they said it should run at 120?
    Maybe it is a layout issue on the EA dev board or something along these lines.
    Cheers.
    Mac
  • Ok so another update on this topic.
    I contacted NXP support and they told me something different than the FAE.
    Here is support's response:
    "Thank you for contacting NXP Semiconductors.
    The EMC in the LPC177x/8x family can run at a maximum speed of 80 MHz (see the Tcy(clk) = 12.5ns minimum in the data sheet).
    You should divide the clock down using the EMCCLKSEL registers."
    I guess I missed that in the datasheet.
    Hope this is of use to someone else.
    Regards,
    M
  • Now it's 80 MHz?
    Time to make up your minds NXP :-)
  • I believe this is incorrect. The data sheet (Table 15. Dynamic characteristics: Static external memory interface, page 81) is referring to a static external memory.
    The tables after this (Table 16-18. Dynamic characteristics: Dynamic external memory interface, page 83 - page85) are the ones that pertain to running a SDRAM.
    I believe this clock, called the EMC_CLK, is a function of the ouptut from the PLL, and the EMC_CLOCK_DIVIDER, as shown in the user's manual on page 35, Fig. 7.
    According to Section 4.6.3 on page 51 of the user's manual, this clock can be the same as the CPU clock, and the CPU clock can be 120Mhz, so this clock can be also.
    I personally have driven my EMC clock at 108Mhz without and problems from my EMC or the SDRAM (MT48LC2M32B2).
    I did experience a problem running it at 120Mhz, but I attributed this to a poor PCB layout.
    I hope this helps,
    -Dave
  • Good observation.
    I too was able to run at slightly higher rates than 80MHz but I think this is actually the "official" limit for the EMC (static and/or dynamic).
    The "clock cycle time" is more directly related to dynamic memory than static so maybe this is just in the wrong spot in the datasheet?
    Also, in our target product we have static mem as well so that pretty much decides that.
    Thanks.
    M
  • After reading your response, I decided to play around with the values used to program the EMC, and now I am able to get my SDRAM to work at 120Mhz.
    Here are my results:
    ...clearing SDRAM (8388608 bytes)...............complete! (92 ms.)
    ...testing SDRAM 16-bit write (2097152 words)...complete! (154 ms.)
    ...testing SDRAM 16-bit read (2097152 words)....complete! (310 ms.), Errors: 0
    ...testing SDRAM 32-bit write (1048576 dwords)..complete! (87 ms.)
    ...testing SDRAM 32-bit read (1048576 dwords)...complete! (148 ms.), Errors: 0
    You are welcome to try it for yourself. Here are the values I used:
    LPC_SC->EMCCLKSEL = 0x00000000;  // EMC uses a clock rate equal to CPU clock rate...
    LPC_SC->CLKOUTCFG = 0x00000100;  // enables clock, sets clock source as CPU clk / 1...
    CAS_Latency = 2;
    RAS_Latency = 2;
    DelayConstant = 0x00000A05;
    LPC_SC->EMCDLYCTL   = DelayConstant;
    I still believe the time entry in the datasheet is specific to the table that it is listed in, namely static memory. It is referenced throughout that table in other timing parameters, but no where else in the data sheet.
    I put in another tech support request to NXP for clarification on this subject, and referenced this forum thread for them...
    Good luck,
    Dave
  • Dave,
    Please post any NXP response here. Thank you.
  • For sure, I will. I also will be posting it at this new forum I just signed up for, which is LPC specific:
    www.lpcware.com/.../lpc17xx
    Hopefully, as this processor becomes more popular, others can contribute there as well...
    -Dave
  • I got a response from NXP:
    David
    The maximum clock frequency of the EMC is 80 MHz.
    In the data sheet, it specifies Tcy(clk) clock cycle time = 12.5ns min.  This equates to an 80 MHz clock.
    You can divide the main clock by two by using the EMCCLKSEL register.
    Regards
    Paul
    So naturally, I responded with this:
    I received this response:
    >Regards
    >Paul
    However, I disagree with these statements.
    If you look closely, you see that Tcy(clk) (listed in Table 15 on page 81) refers to "Static external memory interface". The value for Tcy(clk) is uses as a basis for many other parameters within this table.
    Tcy(clk) is used as a parameter for the SSP, USB, SD/MMC, etc..., and in each case is defined for that particular device/condition.
    My interface is to SDRAM, which is dynamic memory, and I believe better suited to parameters listed in Table 16 on page 83. Since there is no minimum time listed in this table, I presume the maximum clock would be the maximum value for EMC_CLK, which is the CPU clock frequency.
    I have tested this, and am using my SDRAM at 120Mhz without errors.
    Can you please verify your answer for me.
    Also, would you please address Table 19 on page 86 - here, the minimum value for Tcy(clk) is 40ns, or 25Mhz. This cannot be true.
    Thank you in advance,
    -Dave
    I'm waiting on a response once again...
    It would be helpful if someone else with with SDRAM connected to their LPC1788 could test their device at 120Mhz to verify it works correctly. You can find my initialization code for the EMC here to use as a reference:
    www.lpcware.com/.../dk-57vts-lpc1788-configuring-emc-sdram
    -Dave
