Hello, Can anybody tell how to implement USB in LPC3250.?? As their is no example code available i am finding it difficult.. any suggestion,idea,help..PLEASE..!!! Thanks in advance..
Look at the examples for the LPC3180.
I've only done brief and fundamental checks with USB on the LPC3250, but the LPC3180 examples appeared to work.
What about the "Sample Code Bundle" or "Common Driver Library" or "Board Support Packages" mentioned here: " href= "http://ics.nxp.com/products/lpc3000/lpc32x0/">ics.nxp.com/.../ ics.nxp.com/.../
ics.nxp.com/.../
Andy's link of 's MDK-ARM and RVDS (Jul 1, 2006)" that I used.
Direct link:
ics.nxp.com/.../code.bundle.lpc3180.keil.zip
Thank you very much for your valuable reply.
I have downloaded the the zip file related to lpc3180. now i am able to run it also but on host side(PC) windows os is not able to recognize the device. i am getting the message "USB DEVICE IS NOT RECOGNIZED". its asking for driver.
so where can i get driver for my custom board...
Extract from readme.txt of the Code Bundle:
Keil provides a Windows GUI utility HIDClient. This utility can be used to test LPC318x USB device:
That's the one I used.
I have followed the above steps but I can not get my lpc3250 board (using phycore from phytec) to enumerate on the PC. the device fails as soon as the example code is started. Has anyone else had this issue when implementing the 3180 example on the 3250? The phycore uses the same transceiver as the 3180 example. Any help appreciated.
So have you contacted Phytec ?
I've just gone back and had a look at the project I used.
I made one change in the file usb318xcfg.h
It was originally:
#define OTG_1301_DEV_ADDR 0x5A
I changed it to:
#define OTG_1301_DEV_ADDR 0x58
Also I made a note of:
"SDRAM ***MUST*** be initialised for USB sample code to work"
I only ever did this to test the circuit and some principles, it was not (and still is not) necessary for me to do anything further with the USB. You might like to follow them up though.
As Andy suggested, you might want to contact Phytec about it - Or at least check their website. They have a few pages of FAQs about their boards.
Yes, I have contacted Phytec and currently waiting on a response. I have had a look at their FAQs relating to this example (running on one of their other boards) but none of them seem to be relevant to this board.
I had changed that device address but the SDRAM point is interesting, I will follow that up next.
Thanks very much for your help, much appreciated.
