Hi, I am new to micro-controllers word. I am trying to burn the example code "Hello" to C167CR-LM device (it located in C:\Keil\C166\Examples\Hello). I entered the device to bootstrap mode, and connected to it with the software. However I don't succeed to program the flash, or erase it. after connecting I get the following in the log text box:
*Loader file Prepare *Minimon file Prepare *send Byte 0+ Loader + MinimonCore *RECEIVE - MC-Identifier: C5 *RECEIVE - LoaderACK 01 received *RECEIVE - Minimon ACK 03 received *Minimon successfully launched *Reset: BUSCON0=0680 *Reset: SYSCON=0490 *Reset Configuration: External Bus enabled *Reset Configuration: 16 Bit demultiplexed Bus *Reset Configuration: WR# acts as WRL#, BHE# acts as WRH# (P0H.0=1) *Reset Configuration: On chip watchdog timer is enabled (RD#=1) *Reset Configuration: Lengthened ALE signal *Initialisation: Write to SYSCON *Initialisation: Write to BUSCON0 *Initialisation: Write to BUSCON1 *Initialisation: Write to ADDRSEL1 *Initialisation: Write to BUSCON2 *Initialisation: Write to ADDRSEL2 *Initialisation: Write to BUSCON3 *Initialisation: Write to ADDRSEL3 *Initialisation: Write to BUSCON4 *Initialisation: Write to ADDRSEL4 *Initialisation: Enable X-Peripherals via SYSCON
I chose the default stuff after selecting C167CR in the "controller type".
I loaded the "Hello.H86" file, and after selecting target->download selection I got in the log text box: "*ERROR: download not successful"
I tried to erase the flash, not success.
what do I miss ?
