I Have implement simple code where my Processor (LPC2388) is configured as Server & is in the Listen Mode & client which is connecting the Server (LPC2388) is a Linux OS Server. There i am simply connecting the server & Transmitting the Data. But the Problem is that while the communication is going on the controller receives the Duplicate Packet & retransmission Packet Which results in Termination of the socket.
Same thing when i implemented it with Windows OS It works fine Without any issue.
Please Help me for this since it is very important issue due which i m stuck in the module of TCP/IP Communication With LINUX OS
Waiting For Reply
Thank You
And have you spent any time logging what happens in the network driver?
Yes I did that & based on that only i got to know that this is happening. This i tried with Window OS also but it is working fine without issue. But still facing problem when it comes to Linux OS
I faced the same problem with my Linux OS. I tried many possible process but could not be solve the problem. Now I have been searching laptop repair service center for getting the solution.
