Hi, The code is given below.
void CSToOut(void) { static unsigned char data bSimulate[8] ; int I; for( I = 0 ;I < 8;I ++) { bSimulate[I] = 0x01 << I ; ComOutChar( bSimulate[I] ); } }
result: 00 00 00 00 00 00 00 00
why?
Maybe a problem with the ComOutChar function or your use of it?
void ComOutChar(unsigned char OutData) { SBUF = OutData; while(!TI); TI = 0; }
tks.
You tried single stepping in the simulator?
I = 0 ; bSimulate[0] = 0x01 << I ; I = 1 ; bSimulate[1] = 0x01 << I; I = 2 ; bSimulate[2] = 0x01 << I; I = 3 ; bSimulate[3] = 0x01 << I; I = 4 ; bSimulate[4] = 0x01 << I; I = 5 ; bSimulate[5] = 0x01 << I; I = 6 ; bSimulate[6] = 0x01 << I; I = 7 ; bSimulate[7] = 0x01 << I; for( I = 0 ;I < 8;I ++) { // bSimulate[I] = 0x01 << I ; ComOutChar( bSimulate[I] ); }
result:01 02 04 08 10 20 40 80
I = 0 ; bSimulate[I] = 0x01 << I ; I = 1 ; bSimulate[I] = 0x01 << I; I = 2 ; bSimulate[I] = 0x01 << I; I = 3 ; bSimulate[I] = 0x01 << I; I = 4 ; bSimulate[I] = 0x01 << I; I = 5 ; bSimulate[I] = 0x01 << I; I = 6 ; bSimulate[I] = 0x01 << I; I = 7 ; bSimulate[I] = 0x01 << I; for( I = 0 ;I < 8;I ++) { // bSimulate[I] = 0x01 << I ; ComOutChar( bSimulate[I] ); }
result:00 00 00 00 00 00 00 00
unsigned char J; I = 0 ; J = 0 ; bSimulate[J] = 0x01 << I ; I = 1 ; J = 1 ; bSimulate[J] = 0x01 << I; I = 2 ; J = 2 ; bSimulate[J] = 0x01 << I; I = 3 ; bSimulate[I] = 0x01 << I; I = 4 ; bSimulate[I] = 0x01 << I; I = 5 ; bSimulate[I] = 0x01 << I; I = 6 ; bSimulate[I] = 0x01 << I; I = 7 ; bSimulate[I] = 0x01 << I; for( I = 0 ;I < 8;I ++) { // bSimulate[I] = 0x01 << I ; ComOutChar( bSimulate[I] ); }
result:80 80 80 00 00 00 00 00
tks
Why is bSimulate declared static?
What does the assembly that the compiler generates look like? I often find that looking at the assembly listing gives a lot of good information to help with debugging.
