Hallo
I only can set breakpoints in the disassembly windows. Cant do it in the C files?????
It has worked but now its a problem...
No info from the uVision, nothing in Keil support..
Any ideas???
/Thomas
uv4 seems to have a problem when assembly code (embedded assembly) and C code and intermixed in the same C module. If they are separate, however, the problem seems to get solved.
