Hi, I have trouble getting interrupts to work.
I am using the AT91SAM96RL64 processor from Atmel with the Keil compiler and uVision 4.
Initially I have successfully configured UART0 to send and receive data using a polling method. I now have modified the code to use interrupts but the interrupt handler is never getting called. I have enabled the UART0 in the PMC and configured the associated AIC registers.
// Enable in PMC AT91C_BASE_PMC->PMC_PCER = 1 << AT91C_ID_US0; . // UART config is here.... . // Set up interrupts AT91C_BASE_AIC->AIC_IDCR = 1 << AT91C_ID_US0; AT91C_BASE_AIC->AIC_SMR[AT91C_ID_US0] = 0; AT91C_BASE_AIC->AIC_SVR[AT91C_ID_US0] = (U32)UART_Isr; AT91C_BASE_AIC->AIC_IECR = 1 << AT91C_ID_US0; // Enable receiver and transmitter AT91C_BASE_US0->US_CR = AT91C_US_RXEN | AT91C_US_TXEN; // Enable receive interrupt AT91C_BASE_US0->US_IER = AT91C_US_RXRDY;
Any help would be appreciated.
