not able to use flash magic tool in linux ubunt - MCB 2300 board not detected
Hi All,
Hope everyone is doing good. I am working on MCB2300 kit on Windows for quite some time. It is working well. But now I need to use the same kit on Linux. I have installed Keil IDE on linux Ubuntu with the help of Wine. IDE is working fine. But problem is with flash magic tool. I have installed Flash Magic also on Linux Ubuntu with the help of WIne. In flash magic GUI, it takes COM 1 but in Linux we don't have COM 1. It takes as ttyS0, ttyS1 etc., I have tried to map ttyS0 to COM 1 with the following command
$ ln -s /dev/ttyS0 ~/.wine/dosdevices/com1
In the above command we cannot give COM 1 and we need to give COM1 only. And in the GUI it will take COM 1, COM 2 etc., So I am not very sure with above mapping, system is able to take ttyS0 as COM 1 or not. Ultimately I am not able to dump the code on kit using the flash magic tool.
I guess someone has already used flash magic on linux successfully. Please help me to get out of this loop.
Thanks in advance
Regards,
Pavan
