I have installed the latest Code size limited version of your MDK-ARM on Win XP. I am using a STM32-Discovery board.
My problem is the Flash download of my project:
When I run download as "normal" user I get the ErrorMessage (PopUp) which says: "No STLink detected!" (ST-LINKIII-KEIL).
When I do the same as a user with "Admin" permissions everything works properly.
Where can I find and fix the problem?
Best Regards Hello,
Best Regards Andreas
IDE-Version: µVision V4.13a Copyright (C) 2010 KEIL(TM) Tools by ARM
License Information: aba aba IEE LIC=----
Tool Version Numbers: Toolchain: RealView MDK-ARM Version: 4.13a Toolchain Path: BIN40\ C Compiler: Armcc.Exe V4.1.0.561 [Evaluation] Assembler: Armasm.Exe V4.1.0.561 [Evaluation] Linker/Locator: ArmLink.Exe V4.1.0.561 [Evaluation] Librarian: ArmAr.Exe V4.1.0.561 [Evaluation] Hex Converter: FromElf.Exe V4.1.0.561 [Evaluation] CPU DLL: SARMCM3.DLL V4.13a Dialog DLL: DARMSTM.DLL V1.60 Target DLL: STLink\ST-LINKIII-KEIL.dll V1.5.3 Dialog DLL: TARMSTM.DLL V1.60
Then why not follow the same suggested course of action:
1. Contact Keil support;
2. Contact ST support.
Then you can be the first to report your findings here...
