Hi, AS I am a newbie to this field, please help me in using MCB2360.I wrote loopback code for UART.Able to see simulated output , i.e character typed in Command Window is echoed in the Peripheral Window.But why I try to test in HyperTerminal connecting RS232 straight cable to PC and COM1 of MCB2360, I am unable to see the typed character.Are there any setting for jumpers needed.
int main (void) { /* execution starts here */ int c; init_serial(); /* Init UART */ PINSEL0 |= 0x40000000; /* Enable TxD1 */ PINSEL1 |= 0x00000001; /* Enable RxD1 */ U1FDR = 0; /* Fractional divider not used */ U1LCR = 0x83; /* 8 bits, no Parity, 1 Stop bit */ U1DLL = 78; /* 9600 Baud Rate @ 12.0 MHZ PCLK */ U1DLM = 0; /* High divisor latch = 0 */ U1LCR = 0x03; /* DLAB = 0 */ while(1){ c=getkey(); /* read character */ sendchar(c); /* the 'printf' function call */ } }
