how to sent Letter "A" from Microprossor to Hyperterminal
#include <REG51KJ.h>
#include <stdlib.h>
void serial_init()
        TMOD = 0x20;   //set timer 1 mode to 8-bit-auto-reload
        SCON = 0x50;   //enable reception , det serial port mode to 8-bit UART    REN ENABLE
        PCON |= 0x80;  //set mode 2       by seting SMOD
        TH1  = 0xF3;   //set baudrate to 9600 at 24 MHZ crystal
        TL1  = 0xF3;
        TR1  = 1;       //start Timer
void delay(unsigned int msec)//delay
        int i,j;
        for(i=0;i<msec;i++);
        for(j=0;j<1275;j++);
void serial_send(unsigned char dat)
        while(!TI);     //wait for data to be send completely
        TI = 0;         //clr Transmit interrupt flag
        SBUF = dat;     //move data to send in SBUF
void main(void)
        serial_init() ;
        for(;;)
                delay(10);
                serial_send('A');                  //send char 'A' through rs232 across
  • There is a reason why all delays (and baudrates etc) should always (!) be verified with an oscilloscope. Both when originally implemented, and regularly during the normal release testing.
    It's always so sad to _believe_ that a delay does what the name claims, when it really doesn't.
    Software loops are known to result in the wrong delay times because of the generated code. But even if assembler instructions are used, the code will break if crystal, PLL or similar are changed. And same thing affects timer-based timing.
    In the end, a test plan is always required. And just about everything in the software should relate to that test plan, to make sure that assumptions really are fulfilled and the shipped product does what it claims to do.
  • This code has nothing specifically to do with Hyperterminal; so be sure to make it clear that Hyperterminal is just an example - not a particular requirement.
    Similarly, this has nothing specifically to do with RS232 - that depends on external hardware, and has nothing to do with the code.
