Hello , All i want to config Ethernet peripheral "init_TcpNet " in RTX-OS. i doing add of its configuration file & its library . when i type init_TcpNet (); the compiler relate below errors:
new-Rl-arm.axf: Error: L6406E: No space in execution regions with .ANY selector matching net_config.o(.bss).
new-Rl-arm.axf: Error: L6407E: Sections of aggregate size 0x2128 bytes could not fit into .ANY selector(s).
Can any one help me.
Thanks a lot Amir Zendehdel
Help with what?
"Sections of aggregate size 0x2128 bytes could not fit into .ANY selector(s)."
Sounds like your flash is full. How much flash space do you have? How much flash space do you need?
Hello per Thanks for your replay But i think i have enough space i use at91sam7x256 256 KB flash and 64 KB ram only write little cod in my program SD-Flash and TCP-Net only regard Amir
But one of the errors is that it can't fit about 8kB.
However, I might have been wrong in my previous post. One of the errors explicitly complains about bss - which is uninitialized variables. How have you allocated your RAM? How much for stack(s)? How much for heap? How much for your own program? Any specific settings for the TCP/IP stack?
Hello Per
Thank you veryyyyyyyyyyyyyyyyyy much
it is solved
in rtx config we use many stack ram
but can you invite to me a pdf or website for how to choose stack ram in rtx config
Thanks a lot Amir
I have new problem with TCP NET
the program compile ok.
when we add init_TcpNet in our program then we have below problem:
1- lan led turn on for about 1 sec and then turn off
2- if lan cable was not plugged then Init_TcpNet does not pass and program will paused
3- system does not work
Please help me.
Amir Zendehdel
Did you bother to read the user manual of TCPNet?
Hello Tamir
i read some thing about it on keil website
but if you can please send me its user manual web link.
Thanks a lot\
Amir
http://www.keil.com/support/man/docs/rlarm/rlarm_tn_tcpip_prot.htm
Thank you Very Much Mr.Tamir
