Is RL_USB possible to create composite deivce on runtime
Hi
Our system has a USB device port and SD card slot, the SD card is optional, so there are 2 cases:
1. Connect the USB to PC, it needs to be a HID device.
2. Insert SD card, then connect USB to PC, it needs to be a HID+MSC composite device.
I am using RL_USB, this means I need 2 usb configuration: one for single HID device, the other for composite HID+MSC device, firmware needs to detect if sd card is inserted to decide which configuration to enable. However, it seems I can only config the usb class in compile time, and not able to change it in runtime??
Am I right? What's the general solution for this requirement? I am using RL_USB library.
Thanks.
  • You may always expose HID + MSC configuration to host.
    The MSC interface returns NOT READY - MEDIUM NOT PRESENT sense data while no SD card is inserted. I believe Keil SD reader example implements this response.
    Tsuneo
  • In this way (use CheckMedia), if sd card not inserted, windows still display an disk icon "Removable Disk", if you double click the disk, you get a message: please insert a disk into drive.
    What I would like is that windows DO NOT display that disk icon until sd card is inserted! is this possible?
    PS:
    My home pc has a built-in sd slot, windows always display "Removable Disk" icon, no matter sd card is present or not.
    If I use a USB-SD converter, connect the usb to pc, windows always display "Removable Disk" icon, no matter sd card is present or not.
    Don't know if this is the general solution.
  • If you get your device to disconnect and reconnect, you cn have it enumerate as a disk only when it has a SD card inserted.
  • > Don't know if this is the general solution.
    It's the Windows way.
    As of configuration change using soft-detach,
    Windows WRONGLY assume single configuration for each USB device, though USB spec allows multi-configurations. To switch configuration on Windows, soft-detach / attach is used as the last resort. In this case, you have to assign different VID/PID (at least, PID) to the new configuration, because Windows ASSume single configuration for each VID/PID.
    Tsuneo
  • Yes, I want this solution: use 2 configurations, and use soft-reset to select different configuration, but problem is: does RL_USB library support this? I can't see any usbd_xxx functions to change configuration in runtime, seems I can only make one configuration in the USB_Config.c source file, then compile to one single static configuration!
    I guess I must change RL_USB source code instead of using the RL_USB.Lib of CM3? But the source code is not provided in MDK4.20, I must copy these source code from early version of RL_ARM? Don't know if there is license problem.
  • > does RL_USB library support this?
    No. You have to rewrite the library source code.
    On the config switch scheme, HID connection is disturbed, every time SD card is inserted/removed. I don't think it's a decent implementation.
    Tsuneo
