I want to have some leds in P2.0~2.3 and show off the "ON" lamp in VB6.0 program though RS232 during the sensors are +5V output to P1.0~1.3 89S52 MCU. But it appears many errors and doesn't work in PC. Please advise me the comments for the following code. Thanks a lot!!
"Please advise me the comments for the following code."
It compiled successfully for me and I got precisely the result I expected when I put it in the PC. How does your differ?
Excellent for embedded use, because of the miniscule footprint.
#include<REGX52.H> #include<STDIO.H> void load1(void);main() { TMOD=0x20; TH1=230; TL1=230; TR1=1; SCON=0x70; while(1) { RI=0; TI=0; SBUF=P1 | 0xf0; while(TI==0); while(RI==0); if(SBUF==0xfe) P2=0xfe; load1(); else if(SBUF==0xfd) P2=0xfd; void load1(void) { P1_0 = !P1_0; if(P1_0==0) send('0'); else send('1"); }
By the VB6.0 for the following codes: Private Sub Command5_Click() tex1.Text = "connectiong" MSComm1.Output = "0" delayms 100 buf = MSComm1.Input If buf = "2" Then LOAD1.FillColor = RGB(0, 255, 0) LOAD2.FillColor = RGB(0, 255, 0) LOAD3.FillColor = RGB(0, 255, 0) LOAD4.FillColor = RGB(0, 255, 0) Else tex1.Text = "fail" End If End Sub Private Sub Command6_Click() On Error Resume Next msg = "are u close?" code = 65 Title = "closed" return_value = MsgBox(msg, code, Title) If return_value = 1 Then Command5_Click MSComm1.PortOpen = False End End If End Sub Private Sub Command7_Click() On Error GoTo OUTPUTERR Dim i As Integer, iFile As String iFile = "d:\test.txt" Do While Dir(iFile) <> "" i = i + 1 iFile = "d:\test-" & i & ".txt" Loop Open iFile For Output As #1 Print #1, Text0(0).Text Directory.Text = iFile Close #1 Exit Sub OUTPUTERR: MsgBox Err.Description, vbCritical, "file failed" End Sub Private Sub Command8_Click() Text0(0).Text = Empty End Sub Private Sub Form_Load() On Error Resume Next LOAD1.FillColor = RGB(0, 255, 0) LOAD2.FillColor = RGB(0, 255, 0) LOAD3.FillColor = RGB(0, 255, 0) LOAD4.FillColor = RGB(0, 255, 0) MSComm1.PortOpen = False MSComm1.CommPort = 1 MSComm1.PortOpen = True If MSComm1.PortOpen = True Then MSComm1.PortOpen = False MSComm1.CommPort = 1 MSComm1.Settings = "1200,n,8,1" MSComm1.PortOpen = True tex1.Text = "set COM1" Else MSComm1.PortOpen = False MSComm1.CommPort = 2 MSComm1.PortOpen = True If MSComm1.PortOpen = True Then MSComm1.PortOpen = False MSComm1.CommPort = 2 MSComm1.Settings = "1200,n,8,1" MSComm1.PortOpen = True tex1.Text = "set COM2" Else MSComm1.PortOpen = False tex1.Text = "no COM" End If End If End Sub Private Sub MSComm1_OnComm(Index As Integer) tex1.Text = "connecting" MSComm1.Output = "P1.0" delayms 100 buf = MSComm1.Input If buf = "0" Then LOAD1.FillColor = RGB(0, 255, 0) ElseIf buf = "1" Then LOAD1.FillColor = RGB(255, 0, 0) Text0(0).Text = Text0(0).Text + "GasSensor-" + Format(Now, "DD.MMM.YYYY.HH:MM:SS") + vbNewLine Else tex1.Text = "fail" End If End Sub
before you do anything else, sort-out the layout of that code so that you can at least see some idea of its structure!
That should make several errors immediately obvious; eg, unmatched brackets...
Sorry!
void delayms(unsigned int time); main() { TMOD=0x20; TH1=230; TL1=230; TR1=1; SCON=0x70; RI=0; TI=0; ES=1; EA=1; while(1) { while(P3==0xff); switch(P3) { case 0xfb: { P1_0=0; SBUF=P1; break; } case 0xf7: { P1_0=1; SBUF=P1; break; } case 0xef: { P1_1=0; SBUF=P1; break; } case 0xdf: { P1_1=1; SBUF=P1; break; } } delayms(100); while(P3!=0xff); } } void scon_int (void) interrupt 4 { if(RI==1) { RI=0; switch(SBUF) { case 0xfb: { P1_0=0; SBUF=P1; break; } case 0xf7: { P1_0=1; SBUF=P1; break; } case 0xef: { P1_1=0; SBUF=P1; break; } case 0xdf: { P1_1=1; SBUF=P1; break; } } } else TI=0 ; } void delayms(unsigned int time) { unsigned int n; while(time>0) { n=120; while(n>0) n--; time--; } }
#include<REGX52.H> #include<STDIO.H> main() { TMOD=0x20; TH1=230; TL1=230; TR1=1; SCON=0x70; while(1) { RI=0; TI=0; SBUF=P1 | 0xf0; while(TI==0); while(RI==0); if(SBUF==0xfe) P1=0x3f; else if(SBUF==0xfd) P1=0xcf; else if(SBUF==0xfb) P1=0x0f; else if(SBUF==0xf7) P1=0xff; } }
I want to output the signal through RS232 to PC(VB6.0) (just show ON/Off lamp on VB6.0)during the switch on/off. Please advise me how to write Keil C in addition base on the above code or provde some information for my reference. Thanks a lot!!
http://www.keil.com/books
www.8052.com/.../RS232gd.pdf
http://www.8052.com/faqs - there's a whole section titled, "Serial Communications Questions"
Thanks! But I want to have more related examples for my reference!!
But what you need first is to get a firm, foundational understanding of the principles.
If you just want examples, there are tons available all over the internet - serial comms must be one of the commonest tasks on an 8051!
There are even plenty of examples on this very site: http://www.keil.com/download/list/c51.htm
The most basic example of serial comms is, of course, the classic "Hello, world" program - see: http://www.keil.com/support/man/docs/uv4/uv4_ex_hello.htm
See also: http://www.keil.com/support/man/docs/uv4/uv4_ex_measureovw.htm
Thanks! If i have the following codes, how to write the code through RS232 to PC?? Please advise it!!
Please re-read the entire thread from the top. Nobody here is going to do your homework.
Do you actually understand what it's doing?
If you do, then put in comments to show your understanding.
If not, then clearly that is your basic problem!
Why don't you just start with "Hello World", get to understand it, and work from there?
PS
Your layout is still messy; don't use TABs - they don't work on (most) internet forums - use only spaces for indenting.
Note that any decent editor (including uVision) can be set to insert spaces when you press the TAB button:
Edit > Configuration > Editor > Insert spaces for tabs
I just want to ask the related questions, hope someone can help me. Why you say that!! how come the rules to do it!! If I can solve it, i dont need to post my questions!!
