Hi
I'm trying to use the STM32F10x_StdPeriph_Lib that I have downloaded from stm.com, my problem is how do I tell uVision that it shall not use the default file located a C:\Keil\ARM\INC\ST\. Or to put it in another words, how do I remove the compiler string “-I "C:\Keil\ARM\INC" ”
now I gets thees kinds of errors: C:\Keil\ARM\INC\ST\STM32F10x\stm32f10x_type.h(23): error: #256: invalid redeclaration of type name "s32"
Best regards SPA
Look-up "Include paths" and "Library paths" in the manuals...
I'm having the same problem. I already searched the manual, and I wasn't able to find the solution. Any help?
I am using a recompiled STM32 library and I also had your problem.
One workaround is the following: 1. place your library into <path>/lib/STM32.lib, 2. place all the .h files into <path>/inc, 3. link the STM32.lib, 4. add <path>/inc via menu in Options-C/C++/-Include Paths.
That will solve your problem because the new include path will override the default one.
Another way to solve it is by operating on the device database (menu: File-Device Database) and changing the include path in REGFILE.
The default line is: REGFILE=stm32f10x_lib.h("ST\STM32F10x")
If can change it into: REGFILE=stm32f10x_lib.h("ST\STM32F10x-v3.2.0")
However, you must do it for every device you wnat to change and recreate a new project. Also ... the new include path can be only below C:\Keil\ARM\INC ...
Hi, Marco.
Thansk, I think I will try i out, for now i have just deleted the default inc. and src. folders.
Best regards S. panduro
find one the following line
#include "stm32f10x_type.h"
in the file of stm32f10x_conf.h.
use "//"before this line and then rebuild the project.
Good luck!
You mean, comment-out the line?
That will almost certainly prevent the project from building!
stm32f10x_type.h contains the "portable" type definitions like u8, s32, etc, which are used throughout the library - if you comment-out this header, they will all be undefined!
