Upload from memory to file all 00
I've got a board that's using the C8051F340 and I connected the USB debug adapter on the C2 interface.
In Silabs IDE I can successfully connect to the device, and when I do 'upload from memory to file' it seems to work, but the file only contains '00'
Any idea why?
MowerMan
  • this is discussed ad nauseam in the SILabs forum.
    The SILabs chip to memory is not very 'elegant'
    I suggest you try with the SILabs software
    HOWEVER, all zeroes seems to indicate that you are trying to download from a protected chip. The only way to unprotect a chip is a chip erase
