I can see how to receive bytes from the simulated MCU in a script, but I only see "seconds" variable for execution time, which is not good for me. Is it possible to measure milliseconds?
Using SIGNAL might be a solution, but I worry that running a signal function every 1ms (to update a global variable used in the uart rx handler to check the byte gap timing) will be too resource heavy on the PC.
if you need something like a stop watch, you can reset t1 (right bottom of uV Window) to zero and then measure a part of your program.
If that is not accorate enough for you, you could calculate the cycles difference (can be found in the Register Window) and then - with the CPU Frequency - calculate the time from that.
BR, /th.
Is there any way I can do that programmatically?
