Any one who can help
i am having a problem on how to re - enter data to P89V51RD2 micro controller re- send to the interfaced device in which whose main function codes are inside a while(1) that means always true . my main function is looks like this void main () { variable declaration
lcdInit(); lcdClear(); lcdGotoXY(0,0); //lcdPrint("::::::::::::::::::::"); //lcdGotoXY(0,1); lcdPrint(":: ::"); //lcdGotoXY(0,3); //lcdPrint("::::::::::::::::::::"); delayms(5000); while (1) {
then every thing here function that scans the keypad function that sends to LCD function that sends to the interfaced device
} i am using keil uVision 3 as my compiler . my main problem is how to re- send data to the interfaced device with out resetting it .
Thanks for u help
Resending to what device?
Why would this unknown device need a reset before you send to it?
i have send to the device successfully at the first time , but i want to re-send again (to change the input value if i want) with out resetting the microntroller
The documentation for this unknown device will tell you: 1. Whether this is possible; 2. If it is possible, how to do it.
So: have you studied the documentation for this device?
Have you looked at the manufacturer's website for support - examples, application notes, etc?
www.8052.com/.../160143
You obviously didn't pay attention to the clear instructions on how to post source to this forum:
www.danlhenry.com/.../keil_code.png
You really need to pay close attention to the documentation if you want things to work properly!
