Currently I have LPC1765_Amphibian and evaluation copy of uVision4
Q1) How can I configure the my Hellow World program to run into my machine. (Just to print the text "Hellow World")
Q2) Can I debug using the uVision IDE Only? If not, what be I use and can u recommend?
What I done: In uVision IDE I try to run the sample program "Hellow World" but there no display. However I run successfully. Q: I there a way to print the text in IDE?
I'm not sure if here the right forum. But I think go to right. :)
Thanks in advance..
I also read the user manual of uVesion4. I sound likes it point one device for debugging(ULink).
Qusetion: Is there way to debug without ULINK. If ever I need to run my Application as real process I will download it to may machine(However not sure how to do this).
http://www.keil.com/support/man/docs/gsac/
http://www.keil.com/support/man/docs/uv4/
In particular: http://www.keil.com/support/man/docs/uv4/uv4_ex_hello.htm
