How about we Build a ARM Microcontroller Programmer and Development Board
devices to program smd & bga devices based on a ARM and the 20pin demo board from hitex.
1. To have a LCD 4bit mode for smd & bga devices (on the 14pin & 20pin to use port 1)
2. plugin boards for relays or led display (using port 2)
3. on board Usb programmer or alternative
Or have you seen a cheap good ready built one anywhere.?
  • 3. on board Usb programmer or alternative
    I'm not sure which MCU you had in mind, but NXP has an great application note on creating a USB bootloader which can be used to flash their LPC1700 MCUs.
    If no application is detected, or if a pin is held low, the bootloader will identify itself as a USB mass storage device. You can then drag your application (as a .bin file) onto the drive and it will run when you reset the MCU.
    If your goal is to only program a device, it doesn't get much easier than this. It will not provide debug capability though.
    www.nxp.com/.../LPC1700_secondary_USB_bootloader.zip
