I'm writing here in order to find some help in order to program the TIM1 as PWM and make the port PA8 move, as by now I can't get it.
I've already done some projects, using other timers (TIM2,3...) and every think worked fine but when I use the TIM1 it just don't do anything, I'm using the demoboard mcbstm32 and I've proved that I can't move this port if I set it as GPoutput and move it directly so it's not a hard problem.
The main question is that I've already used the examples given by keil, the one that you can fin in : C:\Keil\ARM\Examples\ST\STM32F10x\TIM1\Example1 but it doesn't work.
I'm using the keil version v3.15 , can't it be a library problem?, in hat case how I change he libraries.
I need help, I don't know what to do and I really need this port works for my company project.
best regards
