Let's say that I have two files in my project: Startup.A51 and test.c
Some variables are allocated in Startup.A51; for example,
REG_STATUS DATA 0A0H
Also, some DATA variables are allocated in test.c.
data char value;
(1) Does the compiler or linker assign the variables to particular addresses (in DATA in this case)?
(2) Does the compiler/linker read the files in a particular order, assigning fixed locations first and then fitting non-fixed ones where ever it can?
(3) Let's say a function is called once at the beginning and then never again. Is the compiler/linker smart enough to reuse those DATA addresses or are they allocated forever?
Thanks for your help!
