Hi, I have MCB2300 board. Using RL-ARM example LEDClient, all are OK. When I create new project and add all files of LEDClient project to my project (include LPC2300.s, main file,...), it does not work. I have not written any additional code line! Is it because of Project Option? What can I do with it? Please help. Thanks very much.
Do you really believe computer programming is like baking a cake - mixing all ingredients and baking (=building)? You must understand what you are doing first. But without clear and concise explanations, nobody here can help you anyway!
Let me explain :
First, I do as RL-ARM user's guide (Example for Sending Data of RL-TCPnet\TCP Socket help). - tcp_get_socket is OK. - tcp_get_state returns TCP_STATE_CLOSED - after call tcp_connect function, socket state is TCP_STATE_SYN_SENT and stay in this state for ever. I think tcp_callback is not called.
I test LEDClient, it run OK (connect to PC server program and send data OK) After that I create another project as above for testing (new project with all files of LEDClient project. after calling tcp_connect, tcp_callback return event TCP_EVT_ABORT
I am new in RL-TCPnet. Please help. Thanks
Have you included the correct 'net_config.c' file in your project...?
Yes, I copy it from Client Example (with some modifictions about IP,... that works in LEDClient example)
Check the options for LPC23_EMAC.c
The Zero Initialized Data and Other Data must be set to IRAM2 [0x7FE00000-0x7FE03FFF].
EMAC has a dedicated Ethernet RAM. Read the errata sheet - Ethernet.2:
www.nxp.com/.../ES_LPC2378_5.pdf
Thanks very very very very much. It's my problem. All are OK for now.
