Hello preprocessor masters/gurus,
I am trying to make a piece of software as easily configurable as possible, by only indicting which port/pin combination controls the hardware:
// SPI master/slave arbitration #define SPI_MASTER_IO_PORT 0 #define SPI_MASTER_IO_PIN 19 #define FIO_PORT_PIN(x) FIO##x##PIN #define SPI_MASTER_REQUEST_IO_BIT_STATUS ( (FIO_PORT_PIN(SPI_MASTER_IO_PORT)>>SPI_MASTER_IO_PIN)&1)
The result I want is this:
((FIO0PIN>>19)&1)
but this yields the following error message:
..\src\spi.c(341): error: #20: identifier "FIOSPI_MASTER_IO_PORTCLR" is undefined</ptr> Are there ways around the apparent failure of the double replacement required here...? Thanks in advance
Ah, it is good to have colleagues and the internet/google! here is the solution:
#define FIO_PORT_PIN_TEMP(x) FIO##x##PIN #define FIO_PORT_PIN(x) FIO_PORT_PIN_TEMP(x)
logic:
Macros that call other macros that stringify or concatenate. If an argument is stringified or concatenated, the prescan does not occur. If you want to expand a macro, then stringify or concatenate its expansion, you can do that by causing one macro to call another macro that does the stringification or concatenation. For instance, if you have #define AFTERX(x) X_ ## x #define XAFTERX(x) AFTERX(x) #define TABLESIZE 1024 #define BUFSIZE TABLESIZE then AFTERX(BUFSIZE) expands to X_BUFSIZE, and XAFTERX(BUFSIZE) expands to X_1024. (Not to X_TABLESIZE. Prescan always does a complete expansion.)
So the final macros look like this:
// SPI master/slave arbitration #define SPI_MASTER_IO_PORT 0 #define SPI_MASTER_IO_PIN 19 #define SPI_MASTER_DISPLAY_PORT 0 #define SPI_MASTER_DISPLAY_PIN 5 #define FIO_PORT_PIN_TEMP(x) FIO##x##PIN #define FIO_PORT_PIN(x) FIO_PORT_PIN_TEMP(x) #define FIO_PORT_CLR_TEMP(x) FIO##x##CLR #define FIO_PORT_CLR(x) FIO_PORT_CLR_TEMP(x) #define FIO_PORT_SET_TEMP(x) FIO##x##SET #define FIO_PORT_SET(x) FIO_PORT_SET_TEMP(x) #define SPI_MASTER_REQUEST_IO_IS_MASTER ( ( (FIO_PORT_PIN(SPI_MASTER_IO_PORT)>>SPI_MASTER_IO_PIN)&1) == 0) #define SPI_MASTER_REQUEST_IO_NOT_MASTER ( ( (FIO_PORT_PIN(SPI_MASTER_IO_PORT)>>SPI_MASTER_IO_PIN)&1) == 1) #define SPI_MASTER_REQUEST_IO_BIT_SET FIO_PORT_CLR(SPI_MASTER_IO_PORT) |= (1<<SPI_MASTER_IO_PIN) ; #define SPI_MASTER_REQUEST_IO_BIT_RESET FIO_PORT_SET(SPI_MASTER_IO_PORT) |= (1<<SPI_MASTER_IO_PIN) ; #define SPI_MASTER_REQUEST_DISPLAY_BIT_IS_MASTER ( ( (FIO_PORT_PIN(SPI_MASTER_DISPLAY_PORT)>>SPI_MASTER_DISPLAY_PIN)&1) == 0) #define SPI_MASTER_REQUEST_DISPLAY_BIT_NOT_MASTER ( ( (FIO_PORT_PIN(SPI_MASTER_DISPLAY_PORT)>>SPI_MASTER_DISPLAY_PIN)&1) == 1) #define SPI_MASTER_REQUEST_DISPLAY_BIT_SET FIO_PORT_CLR(SPI_MASTER_DISPLAY_PORT) |= (1<<SPI_MASTER_DISPLAY_PIN) ; #define SPI_MASTER_REQUEST_DISPLAY_BIT_RESET FIO_PORT_SET(SPI_MASTER_DISPLAY_PORT) |= (1<<SPI_MASTER_DISPLAY_PIN) ;
