startup code not executing in keil
hi i'm new to keil, it has been said that startup code will be generated and by using configuration wizard of keil. i created configuration file using that, but the program is not starting to execute in the config file.
i configured clock frequency etc, but nothing is reflected when i inspect the PMC in the peripherals...
microcontroller - AT91SAM7 series (AT91SAM7SE512)
