Good day to all!
I went through older posts the learn about your experiences about the PPP part of TCP-Net. Seems to work now - fine;)
We need GPRS at very low power consumption (powered by solar panels)
What GPRS modems did you use successfully with Keil PPP?
Can the modem code be some sort of generic or is there always large amount of code directly depending on the modem model?
many thanks in advance
PPP is independent of any particular modem!
yes, obviously, once PPP is up and running. I was wondering about the setup- and dial-phase in advance and if it is possible to keep the modem dependent part small.
And most important: I was asking for modem recommendations primarily.
thx
