Hello everyone,
I tried to install an driver via INF-file for USB-CDC (based on mcb2300_vcom.inf) on Windows 7 Professional x64 (in the following text called 'target system'). This is to get a COM-Port to send data via USB to an LPC2368 microcontroller.
The installation failed the first time with the message that the driver is not a x64-based system driver.
So I changed the driver as described in MSDN-article for "Cross-Platform INF Files". After a day of hard mind-work I finished the driver and tried to install it again. Now the installation starts on the target system, gives a message about the missing signature, and finishes with following message:
Driver software was found, but an error occured while installation. The device could not be started. (Code 10)
I checked the INF-file with ChkInf (WDK 7.1.0) on the target system and got only one error (no warnings):
Line x: ERROR: (E22.1.1081) Directive: CatalogFile required (and must not be blank) in section [Version] for WHQL digital signature.
I do not think this error is the reason for Code10.
I furthermore checked the usbser.sys on the target system. It's version is 6.1.7600.16385. It's date is 14.07.2009 02:06.
I do not know what to do now to make the driver work.
Finally, here is my revised INF source:
[Version] Signature="$Windows NT$" Class=Ports ClassGuid={4D36E978-E325-11CE-BFC1-08002BE10318} Provider=%MYCOMPANY% DriverVer=10/13/2010,5 [DestinationDirs] FakeModemCopyFileSection=12 DefaultDestDir=12 [Manufacturer] %MYCOMPANY%=USBDevice,NTia64,NTamd64 ;------------------------------------------------------------------------------ ; Models sections ;------------------------------------------------------------------------------ [USBDevice] %DRIVERNAME%=InstallXXUSB, USB\VID_c251&PID_1705 [USBDevice.NTia64] %DRIVERNAME%=InstallXXUSB, USB\VID_c251&PID_1705 [USBDevice.NTamd64] %DRIVERNAME%=InstallXXUSB, USB\VID_c251&PID_1705 [SourceDisksFiles] [SourceDisksNames] ;------------------------------------------------------------------------------ ; Installation ;------------------------------------------------------------------------------ [InstallXXUSB] include=mdmcpq.inf CopyFiles=FakeModemCopyFileSection AddReg=XXUSB.AddReg [XXUSB.AddReg] HKR,,DevLoader,,*ntkern HKR,,NTMPDriver,,usbser.sys HKR,,EnumPropPages32,,"MsPorts.dll,SerialPortPropPageProvider" [InstallXXUSB.Services] AddService=usbser, 0x00000002, DriverService [DriverService] DisplayName=%DRIVERNAME% Description=%DESCRIPTION% ServiceType=1 StartType=3 ErrorControl=1 ServiceBinary=%12%\usbser.sys ;------------------------------------------------------------------------------ ; String Definitions ;------------------------------------------------------------------------------ [Strings] MYCOMPANY="The name of my company" DRIVERNAME="XX USB VCom Port" DESCRIPTION="Provides a virtual COM-Port when connecting an XX via USB"
Has anyone hints for me to solve the problem and make the port work?
Best regards
