Dear all, I have one question about below de-assembly result...
C:0x0CE7 C2FC CLR 0xF8.4
I guess machine code "C2" means instruction "CLR",then what does 0xF8.4 mean ?
What I know is: if we see
C:0x0CE7 C23B CLR bVarA(0x27.3)
then we can get: 1. C2 means instruction CLR 2. 3B => 0x3B = 59d. 59d/8 = 7...3 Thus according to 8051 spec this means we try to clear bit variable located at 0x27h bit3 [REF] "In fact, the 128 bit variables occupy the 16 bytes of Internal RAM from 20h through 2Fh"(see www.8052.com/tutmemor.phtml Memory)
if we use 0xFC then we got: 0xFC = 252d. 252/8 = 0x1F...4 Thus I guess we try to clear bit variable loated at 0x3F bit4 !
But bit-addressable memory occupy 0x20~0x2F and thus I am confused that what does 0xF8.4 mean ?
Thanks in advance...
your clearing bit 4 in SFR register 0xF8
Always yo're freind.
Zeusti.
bit area 0x00 - 0x7F is mapped to address bytes 0x20 - 0x2F (16bytes x 8bits/byte = 128bits) bit area 0x80 - 0xFF is mapped to address byte SFRs at direct addresses 0x80, 0x88, 0x90, 0x98, 0xA0, 0xA8, 0xB0, 0xB8, 0xC0, 0xC8, 0xD0, 0xD8, 0xE0, 0xE8, 0xF0, 0xF8 for the so-called bit addressable SFRs. In this region the high order 5 bits point to the specific SFR and the lower 3 bits selects the specific bit in that register. eg: bit 0x20 is located at address byte 0x20 bit no 0 or 0x20.0 bit 0x21 is located at address byte 0x20 bit no 1 or 0x20.1 SFR region bit addressable registers bit 0x80 is located at address byte 0x80 bit no 0 or 0x80.0 or P0.0 bit 0x81 is located at address byte 0x80 bit no 1 or 0x80.1 or P0.1 this is just bit math on the 8051 acrhitecture.
So the assembly code CLR 0xF8.4 means to clear the bit in SFR region at 0xF8 byte address bit no 4 or 0xF8.4 (=0xFC)
