TCPnet & FLASHfs in RTX
Hi all !
Info : working uVision V3.60 on MCB2300
I created an application using theses guidelines :
Add RTX to my project : www.keil.com/.../rlarm_ar_create_newapp.htm
 - Copy the RTX_config
 - Modify device startup
 - Add a retarget.c file with "#pragma import(__use_no_semihosting_swi)
Don't Add SWI file as it is not need (no user swi) :
http://www.keil.com/support/man/docs/rlarm/rlarm_ar_hints_arm.htm
Add TCPnet task in that way :
www.keil.com/.../rlarm_tn_using_withkernel.htm
When I compiled there was an error regarding to "__use_no_semihosting_swi" : It said that _sys_open was referenced.
SO I understand that I had to retarget this function, and found it in FlahsFS example. No pb for me as I will need to use SDcard So that use the FlashFS retarget.c
So Finally I added in projet libs TCTP/TCTPD/FS_ARM driver LPC23_EMAC & MCI_LPC23 (needed by File_config).
But when I run the simulator I got the following error :
Data Abort: ARM Instruction at 00000128H, Memory Access at FFE0800H.
What does it mean ?
0
