Hi, Just want to ask if I can use my Silab USB debug adapter with uVision IDE to debug and program my Silabs C8051f320DK? Is this possible?
thanks gilmar
however, beware, SILabs and Keil are often "out of synch"
The always working way is to use Keil for compile\assemble\link and SILabs for debugging.
I see. Thank you sir.
You will find a driver package on Silabs.com, which allows you to use Silabs adapters in Keil uVision4.
Thanks. I found it and I'm using it right now.
Hi, Just wondering, as I go into the given examples I notice some of the examples define SYSCLK to be 24.5Mhz(like F32x_Comparator0_ResetSource.c example) in some examples it is 12Mhz(like F32x_External_Interrupts.c example) and this SYSCLK was not in use in both example. And what confuses me is that both examples claims it runs at its maximum base on the given comments. My questions: What really is the maximum frequency of the internal oscillator of this uC(f320), it isn't 12Mhz? Does SYSCLK definition something to do with OSCICN register by just defining it in the code?
Hope you can enlighten me on this. Really confused.
What really is the maximum frequency of the internal oscillator of this uC(f320), Hope you can enlighten me on this. Really confused.
check the datasheet, it's there.
BTW there is no "maximum" for the internal oscillator it runs one frequency only. Sysclk can be generated variuos ways and for 12.000MHz you need an external crystal
Thanks Erik.
"... which allows you to use Silabs adapters in Keil uVision4"
Go to the Device Database entry for the chip:
http://www.keil.com/dd/chip/3574.htm
Look under "AGDI Drivers" - there is a link to the SiLabs driver
Thanks Andrew, it redirect me to silabs site. And I need to unplug and replug the debugger to make it work on uV4.
Thanks a lot.
First I thought only jtag will work but now I'm using C2 for uV4.
