8051 to 8051 interfacing program in c
PROGRAM IN C LANGUAGE to transfer data from 8051(philips) port 2 to 8051(philips) port 2...data is two different 13 digit codes which will be represented by a single digit ..
EXAMPLE :: if the two codes are 42006B1B0032 and 42006B1B9AA8 ... then the first one is represented by "1" and the second one is represented as "0"....
we need to transfer the codes from one 8051 to another.... depending on wat code has been read in the RFID reader , the respective values 1 or 0 have to be transmitted from one 8051 to another....
