problem while giving input to 8051
I have use following code for 8051 by NXP(p89v51rd2)
#include<reg51.h>
#define p2 P2
sfr P1=0x90;
sbit led1=p2^0;
sbit s=P1^0;
void main()
        s=1;
        while(1)
                if(s==0)
                        led1=1;
                else
                        led1=0;
I have connected led on port 2 (pin no. 0)
circuit of sensor is here elecrom.wordpress.com/.../
this sensor on black background generate 0 to 1.5 Volt
when i connect ground to port 1 via 1k led glow but when i give output from sensor (IR sensor) output volt of sensor increase to 5V.
Is there something wrong with program?
  • this sensor on black background generate 0 to 1.5 Volt
    I am trying to overcome a problem understanding you.
    do you mean that when you have the sensor alone, the output is 0 to 1.5 V, but when you connect it to a port pin the output is 5V?
    on that assumption my first thoughts would be
    I do not recall if the p89v51rd2 port pins are configurable, if so, you have configured an input pin as push-pull. If the port pin is quasi-bidirectional and the sensor output rises when you connect to a pin, the sensor is open collector output.
  • yes when I have the sensor alone, the output is 0 to 1.5 V, but when you connect it to a port pin the output is 5V
    what is solution?
    what is solution?
    get the datasheet fot the sensor, it is 99.9% likely open collector output, in which case what you see is what you should expect.
