Hi, I am trying to make a simple main program that waits on an External rising edge interrupt from INTO (P2.10 KEIL 1760). The main code does the configuration for the interrupt then sits in a loop. And should wait for the Interrupt to call void HandleInetrrupt0.
I would like to know what syntax is missing in front of the void HandleInetrrupt0() so the compiler knows that it should be called when INTO 0 triggers it. Also I am not sure that this interrupt is enable properly. Since it look disabled from the interrupt vector controller when being simulated on uVision.
/*---------------------------------------------------------------------------- External Interrupt 0 code *----------------------------------------------------------------------------*/ void HandleInetrrupt0(){ //EINT0_IRQHandler } /*---------------------------------------------------------------------------- Main Program *----------------------------------------------------------------------------*/ int main (void) { LPC_GPIO2->FIODIR &= ~(1<<10);//P2.10 as input LPC_GPIOINT->IO2IntEnR |=1<<10; //Enable Rising Edge on INT0 P2.10 LPC_SC->EXTMODE =0x1; //Edge mode while(1){} }
Err "__irq"...?
Ok, I found the solution..
The syntax is as follows.
__irq void EINT0_IRQHandler(void)){ //EINT0_IRQHandler LPC_SC->EXTINT &=0xFFFFFFFF; toggleLED(); }
EINT0_IRQHandler has already been defined in the .s file along with the other interrupts.
