Hello all,
I'm trying to understand the architecture of s3c2440 and wish to interface all components without RTOS to understand how it functions. I'm facing the following problems:
--> I've been trying to compile it in keil but the it gives multiple syntax errors and does not compile. I some how mannaged to solve a few errors and compile the GPIO experiment and debug it. It worked fine. Then when I compiled the UART experiment it does not debug also. probably some mistakes that i've done in the startup file.
--> Using Keil4, what ROM start address and size should I define?
--> While debugging I am getting that some addresses are not accessible because they are write protected or read protected. How can I overcome this?
==> Any startup files other tahn the one generated by the IDE if available will help.
==> Also if there are any basic experiments done in keil and can post them, i will be thankful.
Regards,
Mihir patel
