Hi All,
I am trying to read and write to external memory. and I want to read data from external memory and output to P0
now I have a few questions.
1. do I need to set the ALE, EA, RD, and WR bits? 2. Following is my code, and it seem not to do anything, something wrong?
main() { char xdata *a_Ptr=0x8000; char myX;
while(1) { for(i=0;i<=15;i++) { myX=*a_Ptr; P0=myX; } } }
since my external memory already has data in it, I added a loop to try to read the data and output from P0, but the output is not the data in the flash memory. instead, it output the numbers from 0 to 15. what could be the problem?
... aka "the bible" you would know the answers and have your thing working.
here are the links to "the bible" Chapter 1 - 80C51 Family Architecture:_www.nxp.com/.../80C51_FAM_ARCH_1.pdf Chapter 2 - 80C51 Family Programmer's Guide and Instruction Set: www.nxp.com/.../80C51_FAM_PROG_GUIDE_1.pdf Chapter 3 - 80C51 Family Hardware Description: www.nxp.com/.../80C51_FAM_HARDWARE_1.pdf
Already read all that, don't see anything in C...C...C..
can someone please help
Thank you
rice poatato (what is wrong with using your name) you would be able to read in the manual that as far as C goes xdata is the only qualifier needed. THUS your problem is hardwarre.
Well, then maybe you need to pick a different line of study/work. It's clearly spelled out right on the second page of the first of the linked documents why what you're trying to do can't work. You can't use Port 0 as an I/O port while you're using external RAM.
